rvndraju
I am really impressed with the progress you made so far.
I do have to agree with the safety goggles, it only takes one little peace of steel, or a broken disc for that matter to ruin someones life!!
A recommendation on the roll cage construction, to weld in additional supports to cross brace the " diamond shape. Keep into consideration that if, and when the buggy rolls, the entire weight of the frame, engine, driver and additional momentum will be exerted on the frame...![]()
Thanks for the suggestion but when we analysed the frame using NASTRAN for various loads like 4G, 5G and 7G on the roll-cage, side impact member & front impact it proved that the frame is pretty safe. And also according to SAE BAJA rule book the driver should be abe to get out of the vehicle in 5 seconds as soon as he turns of the engine so if i put that member it would be an obstacle from the driver to get down during an accident or fire.
instead we have planned to weld a member like this
. But we had a contact of my tenant, he is having a car spare shop so we knew the actual price and we where able to bargain & bring down the price to $189/-
But the driver will be sitting lower than as pictured. He is too high. His button needs to be a lot closer to the floor.... He could be thrown out of the buggy with a good side impact (some people forget to use seat belts, like welding hoods and such.... ) and that would just blow.... Lower seat position offers better driver comfort. Should have done the seat BEFORE putting pedals in final position. They go hand in hand......
