rocketkart
if you did not get a Predator thin how do you now if thay got a compression release ?
i know i had these engines apart many of times and never seen a compression release on them so i bet your wrong doc. american and Canada models are probably different.
Well why didn't you say so in the first place?mkay.
im wrong thay do have a compression release on the cam.
Here is a little known fact with the ohv engines from 15-18 hp....one of the only and major differences between them is just the SPRING on the governor lol...yet briggs charges a few hundred more dollars for that lol
Sent from my SCH-I535 using Tapatalk
You'll know it, if the compression relief decides not to show up when you pull that cord. That rope will snap back faster than you can let go. Now I ALWAYS start any pull start after the compression stroke, just in case. That's nine years worth of "never again"!
That's what I was suggesting all along!
Can you be a bit more specific regarding the model range please? Include model numbers if you can. I know that some engines in that range feature differences in displacement.
There hp isn't based necessary on rpm but on hkw quickly that said engine acheives that rpm...
