Gas struts from picknpull nissian pathfinder rear window glass, installed. Needs a little help getting up, but once it's there it stays by itself.
dude, i'm J over your craftsman block grinders!
and nice job on the struts haha
Started work on a latch for the tub as a safety precaution, you don't want it to un-couple and be left with no steering, as I have done twice since I did this modification.
I added a chain tensioner because it was a little loose and really had no other means to tighten it.
I know there is a small hole in the frame at the top on the joint. It will be fixed. Also the axle looks distorted in the picture, but it is only the light.
ROBOTMICKEY, in post #12 you posted pictures of your axle configuration. I need help. I am trying to build something similar except it will have an ice chest on the top instead of the wagon. I am having some serious problems with the live axle set up. I have the same motor and a very similar set up. I am even making the frame similar to yours as I see how successful your setup is with the live axle and your videos look great. Please please give me some guidance. Where did you get your parts? what parts are needed? and how do I set it up. More pictures would be great also. You can send them to me personally so you don't flood the forum post with stuff people do not want to see. Thank you so so so much for any guidance you or anyone else has. As a new DIY'er I will post pics and let people know what dilemmas I run into and what works well. Thank you for everything in advance.
Nick (addicted)
