tacoma is squealing in the rear
Rustydog2010
NZ Nutta :|
New Zealand
Easy way to see if your clutch is slipping is to load it up.
Start in second, change into second, get to about 2.5-3k rpm and then change into fourth or fifth. Once the clutch is released you'll notice the car will rev out, but no increase in acceleration.
I know when I replace my clutch in my S14 Silvia, I needed to adjust the clutch pedal. It was a heavy duty clutch thou. To check, make sure there is 15-20mm play in the pedal before the clutch begins to disengage.
If the clutch pedal has the free play and the clutch still slips, it would suggest the friction disk or the pressure plate are shagged.
Just make sure you check all the basics first, which I assume you have.
Did you buy a brand new pressure plate and friction disk?
OK, so I got some time to test out the clutch. Changing from 2nd to 5th did not really cause the engine to rev out. I tried it about 12 times, and it only revved out once.
The clutch does have free play in it. I have play when taking my foot off the pedal as well as pushing it in
I don't know what is happening. Do you think it might be a weak clutch or a pedal adjustment that is needed.
