Help, don't know what kind of battery to use
To my knowledge, there is NO alternator that you can use as a motor.
If you are dead lucky, you might be able to use an old automotive generator. These were used before alternators were invented. No telling if it would have enough power. I doubt it. Pretty hard to find, and not even worth pursuing IMHO.
hardrock21
Ozark, MO
No go on using an alternator for a motor. You can use a motor for a make shift generator though with no voltage regulation, ironically.
Paul
nileshc
Cary, North Carolina
I found a 24 volt motor with 36 amps. Each battery is 6 volts and 12 amps. I have a circuit below. Will it work?IMG_0576[1].jpg ANother question, if I use a controller and its limit is 40 amps and motor's limit is 36 what will happen? Can you over amp a motor?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I found a 24 volt motor with 36 amps. Each battery is 6 volts and 12 amps. I have a circuit below. Will it work?View attachment 35070 ANother question, if I use a controller and its limit is 40 amps and motor's limit is 36 what will happen? Can you over amp a motor?
Overamping isn't possible. Voltage pushes, amperage is pulled.
hardrock21
Ozark, MO
I am really confused about amps. How does it effect speed, how long it lasts, etc...
You are comparing 2 different units of measure when relating amps to a motor and to a battery. One is a load and the other is the supply. Battery output is measured in amp/hours, not just amps. Motors draw amperage, so they are two different things. Amps don't regulate speed, nor do they effect how long it lasts.
hardrock21
Ozark, MO
What happens to a motor if you have less amps or more
Again, a motor is going to draw only the amperage it needs, you don't need to worry about over/under amping the motor. Amperage is current. You are probably thinking about voltage which is the supply, you can definitely over-volt and under-volt a load, both of which can burn up a load if it's excessive in either direction.
nileshc
But will amps from a series circuit add to a parallel circuit. I have a a picture of my circuit a few post ago. Can someone tell me if the total output could be 36 amps
hardrock21
Ozark, MO
I'm trying to figure out what you are doing exactly. Why are you wanting to make a hybrid parallel/series circuit? Also, remember Amp/hour ratings are for a 20 hour period so trying to get the a/h to be the same as the amp rating of the motor doesn't make sense. Ideally, you would would want substantially more then 36ah worth of batteries to power a 36 amp motor.
Paul
