hardrock21
amp/hours are a relative efficiency rating. More of an industry standard to rate them that way. You can pull more then the amp/hour rating from a battery, it is just considered out of it's efficiency range, so most likely it will create excess heat and lessen the life of a battery. If your setup will only deliver 1.6 amps, you will end up with a motor that won't even be getting enough juice to spin. But chances are it will pull enough to spin, it just won't spin for long with the smaller batteries and not to it's full potential.
Paul
Paul
