New minibike build, and a few others..
Raywelder
Not an Adm¡nistrator
Motor is mostly together. Just needs a catch/can breather, Throttle set up, and I need to figure out how to get the magnets into the flywheel for the alternator.
Just plain Gorgeous. (Pic 1 & 2)
Sitting in the frame (Pic 3)
Clutch backing plate (Pic 4)
Empty Clutch cover bolted on (Pic 5)
Raywelder
2 more
Dang, that's sexy!!!
So, what- the flywheel came without magnets? Will you epoxy them in? Fortunately, they go on the inside of the rim so if a magnet were to lose it's bond, it won't fly out like a bullet! Do you have magnets for it, yet?
Actually- this question just came to mind- Is the inside of the 'wheel machined to a size that will allow the magnets?
Raywelder
Well, if I use the same magnets out of the old flywheel, then the billet flywheel is machined an half in bigger, and I would need to machine a ring to fit. I'm not sure what I'm gonna do yet. Depends if I can get the old magnets out without breaking. And if they come loose, they won't fly out like a bullet, but I imagine it could grenade everything under that flywheel.
I just finished removing the magnets from a factory 18hp Twin 'wheel.
Once I figured out how the heck to do it without breaking them, it was fairly easy. I was not concerned about breakage, I just wanted 'em out.
Don't use a torch- they actually explode! You need to use a drift, and drive them sideways (around the ring, not up or down), and that will shear the epoxy bond. In my research, I found that preserving them intact is aided by using sharp knives or files to remove the excess epoxy around the magnet before trying to drive it out.
Raywelder
I'll have to give that a try.
I hope I can get em out. I only have one flywheel though! I guess I have one shot.
Raywelder
New gas tank, About the same shape, but it will be welded on the inside too, so I can sand down the welds on the outside though.
First picture is my first attempt
Adjusted the shape a bit.
Raywelder
Machined my fuel cap flush mount piece,
Fitted,
Welded and molded in.
Seams welded and sanded. still needs final tweaking.
Still have to weld in the tunnel.
exenos
Project Nut
Good to see some work getting done on this thing. I was beginning to worry that no one would ever see the finished product.
Raywelder
Raywelder
Done a few things here and there. Most of it is small stuff and I usually don't feel its worth documenting.
Tank and fenders are at a friends to get painted. But I made some handle bars.
Been finding it hard to motivate myself to stay late and work on some of it, Now that I have the Real big stuff done.
That and I have been going back and forth on some color choices of some of the clutch cover and foot controls.
Looking at all the parts I want makes me sick :ack2:
I need to be rich.
Can you believe that these are 120 dollars a piece??? Holy Cow.
Coming Soon,
Mount the headlight
Painted tank and fenders,
LED tail-light/fender support
Micro button housings
Throttle linkage,
Raywelder
Also mounted magnets inside my flywheel finally.
Raywelder
haven't done a ton to it,
Made one of my Switch housings. Just have to duplicate it for the right side.
I bought materials to make bar end signals. We'll see how they end up.
