In case anyone is curious, the total weight of the assembled clutch will be 4.05 pounds. However, the rotating mass is only 2.9 pounds and is the figure that should be used when comparing this clutch to centrifugal clutches on the market. I believe 2.9 pounds is very close to the weight of a standard cent clutch.
Also, the diameter is 4.125" and the length is 2.65".
