Custom manual clutch
B.M.800
TheBeal.
Central PA
That's awesome!
I will surly have to look into saving up some cash for one. Long as it will handle the abuse on an offroad kart/mini setup, that will be great. Heck, i could probably convince my dad to take th kart or bike for a spin... Hehe. That would be pretty funny.
carter
Man I love everything about this, a manual small engine clutch for only 100-150, this is great. Might I ask what the maximum rated HP/torque is? Will you offer models to handle more HP/Torque if need be?
ddowns46
Thanks! We did a static torque test and the clutch started to slip at 42 ft-lbs. This would be easy to increase by simply installing an up-rated internal spring pack (80 ft-lbs is probably the limit until other issues are created by the increased spring pressure). It's worth noting that a built clone motor rated around 20 horsepower will only put out maybe 15-20 ft-lbs, so there's some decent margin.
carter
So it's even strong, this thing is looking more and more attractive as you continue to make it better.
smgs92
How well will these hold up to heavy off road? If they're durable I may try to place an early order for a 1in shaft and run one of these instead of a snow mobile clutch.
fowler
Bullsbrook West Aus
yes i would also like to see these tested in heavy duty aplications (24 hp+)
i wouldnt replace it with a snow moblke clutch
not trying to reduce your sales just for smgs
a snow mobile clutch is a clutch gear box in one so using this clutch will force u to sacrifice either speed or torque
smgs92
I wasn't sure which would be better I kinda assumed the snomo would be but I figured I'd check it would be pretty cool off road though.
carter
How are you gonna work the engagement? Normally engaged or normally disengaged? Will you work it from a pedal or...?
Yes, the clutch is engaged when the lever is released, just like on a car or motorcycle. If we hooked a lever onto the steering wheel, the clutch would be disengaged when the lever is pulled in.
We could actually hook a cable operated lever up to this clutch, but a lever was easier to set up at the time and good enough to prove concept.
Let's not make this poor fella answer the same question too many times, eh? ;)
As far as actuation goes- here's how I see it, and Ddowns can correct me if this doesn't ring true... Like any other manual clutch, a lever is provided, and you can do whatever the heck you want to with it. Cable, rod, pedal, hand lever... Hey, listen- If I wanted to actuate one of these clutches with a hydraulic slave cylinder- no problem... It's a lever...
carter
Psh, read through this whole thread when I can just be repetitive? :lolgoku:
No seriously I should have read the thread before asking things.
ddowns46
Just to keep you guys in the loop, here's a set of renderings for the production parts. The finish will be black oxide coating, these things will look nice!
ddowns46
How exactly does that bolt to the engine? i only see two mount holes.
Two mounting bolts are all that is required. They are for anti-rotation and to keep the clutch from falling off the end of the shaft. Technically, only one bolt is required but having two helps to keep the actuator assembly centered on the PTO shaft.
In fact, we have been using the first prototype with only 2 bolts very loosely torqued with no issues at all.
B man
Tecumseh FTW!
Oliver springs,Tn
but won't that other bolt be in the way of that cable?
ddowns46
No, the second bolt is a low head cap screw that fits inside of the aluminum piece (round silver piece with the radial hole that the cable is passing through). The aluminum piece is the cable housing mount (the cable housing is not shown).The two mounting bolts have to be installed before you can install the cable. Conversely, the cable has to be removed before the clutch mounting bolts can be removed.
