Cotmullion
Mechanical nut
- Messages
- 129
- Reaction score
- 1
Woodruff key:
Straight key:
Clutch with built in key is straight.
Pto pictured uses woodruff key as in pic 1.
They are not interchangeable.
Clutch (Comet?) cannot work on your engine.
This is what will work with your clutch:
Which pic?Russ the first picture looks like the blue pillow blocks on my kart!
Because his clutch has built in key.Just thinking, why wouldn't the woodruff key fit in the straight key slot of the clutch?
Tecumseh are fine. Power to weight ratio a couple of pecentage points higher than Briggs equivalent, but high performance parts are hard to come by.I am also thinking about a Tecumseh 3.5hp 4 stroke. Are these any good, and do THEY have a straight keyway?
