Need Fenders!!
rucinskj
Ok im building a Honda odyssey fl250 with a custom front end with custom suspension, 07 skidoo mxz440x racing motor, fully rebuilt and strengthened transmission and frame, custom roll cage, and I need fenders the tires are spaced 2.5" wider cause I had to get spacers because the snowmobile engine was wide. I was thinking maybe bending sheet metal but anybody know any aftermarket options??
MMarty
I just went to a farm supply place and bought trailer fenders. Cut them down to length and make some mounts out of round or square stock. One 14 inch trailer fender will make 2 buggy fenders.
rucinskj
Thanks. you guys rock. yeah got this baby for 100$ it looked like a pile of junk. its amazing how I made it so far. how do you guys think I should mount the coffin gas tank???
Amped
Port St Joe, Florida , U.S.A.
Were are you? If your not to far from me I have some quad fenders that could be modified to work. You can have them if you pay shipping. Depending where you are might be too costly.
Add some good pics from different angles of the rear and the tank. We love pics here . That is a sweet set up . What size tires are those?
:welcome2: to the forum. You have one sweet buggy going there. Well done. I love the blue paint job. Did you get it as a wrecked FL250? Have you got any BEFORE pics?
Have a look at these threads for some ideas
http://www.diygokarts.com/vb/showthread.php?t=10051&highlight=fenders
http://www.diygokarts.com/vb/showthread.php?t=17888&highlight=fenders
http://www.diygokarts.com/vb/showthread.php?t=14626&highlight=fenders
Fenders? To heck with fenders!
That's what your helmet and goggles is fer!
Aaaah, Toystory, how quickly you forget. :D:D This was posted by you a while ago.
Gotcha. Yeah, I've got a similar problem- I'd like to put front fenders on my kart. The 2 different sets I have are both trailer fenders so I'd have to try and re-radius them, too. When I'm buzzing around in the gravel, and more so in the rain, the front tires shower me in crap...
rucinskj
I got it as a basket case. Built it from the ground up. Got tons of pics. Will transfer from phone. I took a picture after basically every screw I put in. The last thing I built nobody believed me and thought I bought it so this time ill have a nice diary!
beansdaddy78
JR. Member
Carbondale IL.
that is bad arse. I likes amped's idea using quad fenders. A but more sleek look I would think. Depends on what look your going for I guess, geek or sheek
bighead
Pacific Northwest USA
Put some original FL250 fenders on it? You already painted so that might be a problem now.
Or get a 55g plastic barrel and make your own. Use the bottom of the barrel for the flat side. The bottom of the barrel is rounded so use the bottoms of the barrel and not the top with the ridge. Buy an old busted up FL250 fender for pattern.
I seen T-Man makes some cool fenders out of new snow shovels.
This forum is just loaded with smartasses...
...including myself... :D
mysteryboy28
Lansing, MI
i bought a 4x8 sheet of the white plastic panel material from Home Depot (smooth on one side, textured on the other), cut rectangles out of it (rounded the corners, using a large washer for a curved template), made some curved mounts out of some steel bars (slightly bigger than 1/4" for strength) and welded them on. trick is in painting them. did the bottoms black first, then mounted them on the curved metal mounts so the paint would dry curved (didn't want any cracking). once that was dry THEN i welded them onto the buggy.
rucinskj
Nice that's one sweet kart man I would love to build a two sweater but high off the ground. Thanks for the tips to get my creativity going.
