hydraulic brakes questions
Pitbike juice kits can be had pretty cheap on EvilBay. An alternate option is a wrecking yard. Depends on your skills and available tools.
gsegovia
houston,tx
you need more of a description, like what size axle, how fast does your kart go, whats yours budget. if your budget is around 100-200$and supposing you have a 1¼ inch axle, a great kit is http://www.ebay.com/itm/MCP-Hydraul...pt=Race_Car_Parts&hash=item3378c2f999&vxp=mtr this should be great.
I did have a detail description at first,but my phone crashed on me when I went to submit it. I was looking to keep it under a 100$, I got a one inch axle, plan on using 18 or 20 inch tires, 11hp engine with torque converter. Thanks
jfxwave
Corpus Christi, Texas
@Swabbster
I think the fluid of the cylinder is not enough so I don't think it would work because if you have 2 calibers it would need twice the fluid that 1 needs so you would need a bigger cylinder to push more fluid. I don't know how much that cylinder holds so you might want to check and see how far you will have to push the pedal to close both calibers.
gsegovia
houston,tx
@Swabbster
You had me going for a bit there, your replying to the question on the video.a member posted that in here so I can see the brake setup, to reply to it you'll have to log into you tube. Thanks
gsegovia
houston,tx
Ok, how about two of this, the go kart I have had the Rear setup for twin band brakes so I can use the bar for two of this kits ill still come out cheaper then paying 180 for one of those twin piston calipers. Will that work
Swabbster
that kit is fine, that caliper is a 2 piston, one on each side, there very strong calipers, most 200cc atvs run about 10hp and they stop fine,
gsegovia
houston,tx
Well my plan is to test it out and see how it works out, if two are need then ill go for the next one. Thanks
gsegovia
houston,tx
am looking for a hub for this brake rotor it is, the bolt circle is about 2 1/4 inch, and the center hole is just under 1 1/2 any idea where i can find one, maybe some tips on how to make one thank you.
