gsegovia
Where can I find some good and affordable hydraulic brake setup. Thanks
go on ebay and pick up a atv brake setup, you can get them for around 50 bucks
ATV or motorbike, then simply fab up a few bracketsyou need more of a description, like what size axle, how fast does your kart go, whats yours budget. if your budget is around 100-200$and supposing you have a 1¼ inch axle, a great kit is http://www.ebay.com/itm/MCP-Hydraul...pt=Race_Car_Parts&hash=item3378c2f999&vxp=mtr this should be great.
go on ebay and pick up a atv brake setup, you can get them for around 50 bucks http://www.youtube.com/watch?v=149AxnAMMrQ
Pitbike juice kits can be had pretty cheap on EvilBay. An alternate option is a wrecking yard. Depends on your skills and available tools.
I'm nearly certain that anything you buy will require a bit of welding, if even a simple bracket.
@Swabbster
I think the fluid of the cylinder is not enough so I don't think it would work because if you have 2 calibers it would need twice the fluid that 1 needs so you would need a bigger cylinder to push more fluid. I don't know how much that cylinder holds so you might want to check and see how far you will have to push the pedal to close both calibers.
that kit is fine, that caliper is a 2 piston, one on each side, there very strong calipers, most 200cc atvs run about 10hp and they stop fine,
Well my plan is to test it out and see how it works out, if two are need then ill go for the next one. Thanks
