truck talk
Orange Krate
North Texas
I just got this home yesterday. It used to be mine. I did a little to it then sold it to a coworker. He did a little then had to sell it. I wanted to at least be able to drive it before it was gone so I bought it back. Hoping to sell at a profit after having a little fun first.
Threw on a set of free, 15" used tires just to be able to drive it. Those are hard to find...that's why they're so tiny:roflol:...it's all I could find.
Bluethunder3320
that body looks in great shape! nice truck. what year, motor?
as for the rubbing i havent checked where it is yet. i heard from the ford truck forum i need to get aftermarket camber bushings for any lift, even a 3 inch spacer. (i have ttb axle)
since ill be using the truck for carrying things also, i think a 2 inch block under the rear leaf spring should be good enough. the back is much higher than the front
people are telling me to just get a full 4" lift kit, but those are over $1,000 as opposed to a 3 inch spacer that's under $100.
and as for body lifts, it would be a LOT of work. id have to raise the bumpers, change the radiator mounts, modify the 4x4 shifter linkage, extend the steering shaft, unmount the cab and bed and put spacers under them, and my shifter would be lower in the floor
Blazkowiez
Kart Aficionado
Houston, Texas
Orange, I love the way that old boy looks. That is one cool old Ranger.
Orange Krate
North Texas
Thanks guys! 1970 F100 completely rebuilt 360 and C4. Won't shift to 3rd and the steerings loose. I'm working on that today when I get off. One of my many projects. It's only the go-kart garage that has the one project enter - one project leave rule. LOL
mrfreyguy
Buggy Almost Done
Iowa
you might laugh at me... but i am seriously considering putting a TURBO in this truck. lots of room now!
saw a forum where a guy did it... he had 230HP and 451 ft/lbs 15lbs boost. stock is.... 145?hp and 260 lb ft
not sure how complicated it is to set one up. or the cost either...
EDIT: looks like it would be pretty complicated, id need a computer... and route the exhaust into the turbo/?
You cant pump 15lbs into a stock engine without building it up to handle that much boost. A safe range for an origionally Naturally Aspirated engine is about 5-7 psi, once you go higher you have to lower compression, re tune, run premium fuel, and address other things like your fuel pump, larger injectors, cooling, etc. Leave the motor stock and just drive it till it dies.
Bluethunder3320
yeah i dont know what i was thinking lol. its not simple as i first thought, ive seen someone with a turbo they slapped on a scooter, i guess its more complicated in a car.
Orange Krate
North Texas
Pardon me while I hijack this thread...does anyone know what this is hanging from under the column of my '70 f100?
Bluethunder3320
fowler might be right about the steering/tilt thing. or maybe even parking brake or something to do with the lights or wipers?
emergency flashers?
mine doesnt have steering wheel adjustments. and thats an 89. if it was steering tilt, i wonder why they wouldnt have it 20 years later? technology should be going forward. but thats not always true (if it was a bad design they may have just got rid of it)
newrider3
Colorado
It was optional as far back as '78 I believe, it just wasn't frequently purchased.
kendelrk
redneck engineer
westland michigan
I have no idea on what it is, but for some reason i seem to think maybe an adjustable brake pedal. that little uprose picture seems to remind me of the one on my adjustable brake pedal button
Bluethunder3320
post it on the ford truck enthusiasts forum. i dont mind this on my thread. but the people at FTE should be able to tell you what it is.
Orange Krate
North Texas
I did and they were kind of ****s to me and I'm not even a new member there. But it was my fault...aparently linking to pics hosted here are nor viewable to them there:oops:
Anyway, a buddy and Ford NUT at work figured it out. It's the neutral safety switch. Goes on TOP of the column where I couldn't see where it went....Carry on
