truck talk
fowler
Bullsbrook West Aus
a device for lifting or pulling
http://www.kensalrental.com/Come_Along_pic.jpg
a feild mechanics best freind
come in sizes from 500kg to 30t from what iv seen
those are sick tyres
they suit it better than the last lot
its good haveing a vehical u can do stuff like that in
if u had a good truck u would forever be worried about scratches and dents but in these its like
well theres anoughter dent oh well that dent sorta straightened out these other dents
edeit
becareful where u are doing this though
that is likly someones access road to there property
we get people that come do this round our area
it turns a bush road into a rutted messy track and is a real pain when u are trying to get 1/2 million$ machinery that isnt all wheel drive though there in summer
crazzywolfie
Orangeville, Ontario
it is similar to a ratchet strap but is bigger and uses steel cable.
Bluethunder3320
ahh i see. i had 3 nylon ropes and a ratchet strap tied to the bumper and the tree. i gunned it in reverse and it stopped the truck but didnt even bend the bumper back. thats a 6,000lb truck coming to a dead stop. it must have taken a LOT of force to bend that
but since ill be building a bumper in the future im not too worried about it, now that its cut and clears the wheel fine
Bluethunder3320
it wouldn't hurt to have a come along if you plan to keep off roading. they are like the poor mans winch.
oh yeah! thats what i need. i didnt really want to mount an expensive winch on the bumper. i wanted to make hooks though and use some kind of external winch if i ever got stuck.
i probably cant go off roading for like... until i turn 18 in 1 1/2 years... my parents HATE off roading and if i ever came home with a muddy truck again they said they would take the keys and ground me
unless i wash it before i come home :D
ill find a way i guess. the one time i went was real good fun.
Bluethunder3320
they rub a little when i turn all the way and hit a bump. i dont like that so ima get a 3 inch front coil spacer and make my own 3 inch block added under the leafs.
exenos
Project Nut
Well, that solves it. When I need a vehicle it'll be a single cab, short box truck with 31" tires or larger. That looks amazing, although it does have a slight hint of redneck to it, probably the visor.
Edit: LOL redneck is in the auto correct on my tablet :D
Bluethunder3320
i like the way it drives now, it hits bumps softer, and the shifting is less jerky if you arent perfect at shifting. the gear ratio is actually a little bit higher and id say its changed to a couple hundred RPM less to go the same speed with the stock 31's. theres much more traction, but the tires are somewhat noisy at high speeds
i got it up to like 75 and it doesnt wobble much but i usually go bout 55-60 on the highway just below 2,000 rpm in 5th gear. i used to have to rev a little over 2,000 rpm to go that speed.
in reverse it goes a lot faster than before, i used to let the clutch completely out sometimes but now if i do that, im really cruising backwards
crazzywolfie
bigger and wider tires do make a vehicle ride better but you will most likely burn more gas. those fords seem to have a high reverse gear. i know even my dad once in a while stalls while in reverse. i do know for sure that they can do 55km/h in reverse without redlining. my dad has scared many people doing the speed limit down a street in reverse.
Bluethunder3320
i think reverse is meant to just be slipped a little bit. haha thats funny though. i dont know why they'd gear it so high, you never need to go more than 10mph in reverse
Bluethunder3320
lol that video was great
im having some problems with the 33's, only when im in tight spots. this afternoon i was at a gas station and had to face the other way to the pump. i had to go down the street, do a K turn then come back facing the other way. then someone parked in front of me so i had to so some tight maneuvers to get out. then later i was in a tight parking lot and i was forced to turn the wheels all the way to get out. they rubbed a little, not sure where but it was noisy.
normal driving is fine though, it just doesnt like sharp turns
Kaptain Krunch
Pro Junk Collector
vermont
get some rims with a little more offset. cutting the fenders with a sawsall and putting fender flares on is also another cheep trick, rather than lifting.
