I know nothing about this stuff, but I need a metal shop project.
jdmkid
Toronto, Ontario
im pretty much building this kart except im using a cr80 engine instead of the 125 kx. if you want a shifter kart thats fairly good, id look around for a rolling frame with almost everything you need (hub, steering components, etc) and find a used dirtbike engine like a lifan or a chinese brand since they are cheap and fabricate it onto that.
Scarface
Dover, PA, USA
Well I might buy one of my dads friends be up junk go kart and restore it. We will see tomorrow night but do you guys know where to get the parts for the 212cc predator engine?
What is a good Briggs and Stratton motor that is inbetween the predator 212cc 6.5hp and the 346cc 11hp? Or close to one of those. When I looked on there website I went to the racing engines and it does not seem to tell me the HP or cc but I don't know if I was looking at the right thing, if there is a page where all the go kart engines are then just please post a link.
Anybody?
For $100 you can replace the whole engine, why bother with parts? B & S have an 8hp which (I think) is about 250cc. Honda also do a gx370 (9hp IIRC), among others
Scarface
Dover, PA, USA
Ok can someone get me a link to that 8hp 250cc briggs? Oh and for the predator engine where would I get filters and small stuff for if I need something that is 20$ I am not going to go spend 5x that on a another engine.
Scarface
Dover, PA, USA
So can someone get me a link to that 8hp 250cc Briggs? Because I went under racing engines and when I click on them no where it tells me the HP, cc, nor rpm's.
Jcotz
...wasn't there
NY
Well if you plug in the listed max torque and Rpm's into the formula for hp, you get about 5.5hp. The equation is as follows: (torque*rpm's)/5252=hp, so (8*3600)/5252=5.5hp
jdmkid
Toronto, Ontario
honestly, if your gonna spend 200-400 on a briggs or honda gx engine, id rather use a dirtbike engine. 20hp + gears = more fun.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
ok. Most industrial engines spin at 3500 rpms. So that 8hp briggs and stratton is going to spin at 3500 rpms stock. If modified it could spin more rpms, but stock thats all its gonna do. If i were you i would buy this engine... http://www.bmikarts.com/item/-U-Build-It-Box-Stock-196cc-OHV-Racing-Engine-ADJ-1005-6576
That engine should be spinning somewhere around 6000 rpms when its all done up and right, and it should have around 7 or 8hp. Also it just bolts up to a normal mount and you dont need much fabrication to make it work. Its simply bolt up and go. This video will help you build it http://www.youtube.com/watch?v=5sYUCr-EFTU
Use plans like this one but modify them to your needs (size etc. )
http://kartbuilding.net/racingkart/index.html
That way you have a nice racing style kart capable of around 45 mph
Scarface
Dover, PA, USA
I understand some more now, I may be getting a beat up old go kart tomorrow and buy then just restore it. I should also get to test drive some.
fowler
Bullsbrook West Aus
it requires alot of skill on a shaper or a mill custom cut each gear
and probs 3 weeks of work
or u could use a multi belt tensioner setup but that hasnt been done proberly yet
or buy a gear box from harley daverson or some other bike maker that uses a seperate box but thatll set u back a few grand
a bike engine is easy to install and fairly cheap
jdmkid
Toronto, Ontario
bike engine comes with usually 4 - 6 gears depending on the bike. you can get a lifan or some chinese 125cc dirtbike for like 200-500 bucks, and you would have practically all your parts concerning your engine on there. only thing to do would be to fab mounts for the engine, and setup a shift lever and clutch which isnt hard.
