Hey- that's my carby in SA!
Lol. Have you got some taps and drills, and some basic cutting tools
You could quite easily make an adapter like this
Get a block of aluminium or steel, or even plastic may work. I would reccomend aluminium for it's corrosion resistant properties.
Using some oil or marking fluid if you have it, put it on the face of the carb and press it up against the metal block.
Mark centres on the two mounting holes and the throttle bore hole.
Drill the mounting holes to 5mm and the throttle bore to .710" (18mm), or as close as you have in drill bits, then use a rat tail file to get the centre hole as close as you can to the carb throttle bore diameter. you can also shape to the port opening.
Tap the mounting holes to M6 and thread in the carb studs. Chop off any excess stud
Mark two mounting holes to bolt it to the engine, and drill them out to 6mm, and countersink. Using countersunk m6 bolts, you can bolt the adapter to the motor, then bolt the carb to the studs.
Done.
