tool for bird mouthing?
Texas
Just curious, I have been using a chop saw to birt mouth my pipe, it is not easy to get a nice bird mouth from a chop saw, so does anyone anywhere sell a tool specifically used for it? thanks
Herky
wow that is an AWESOME tool!!! I'll have to measure my desktop drill press to see if I can put it on what I have. Yep spent the evening notching tubing with an angle grinder...sucks.
fourtogo
Notching tubes
Cut on band saw, cut two corners off and use a drum sander. Fish mouthing tubes Is done in many ways, but this Is the most basic. Can be done with chop saw. It's the second cut that need more exacting . Grind fit grind fit grind fit, this why chassis shops charge by the hour and the job.
ML-TOYS
long island, new york
I just bought one of those and the $22.00 1/2 drill to keep mounted on it.
jdmkid
Toronto, Ontario
He knows how to fish mouth, he just needs a tool which would give a him a cleaner cut and make it easier to get a good clean cut.
DS13
Annoying the Neighbors!!!
Elysburg, PA
Yeah I know that thread says it works pretty well... I haven't actually tried the paper thing but it looks like a fairly quick way
jeremy schmidt
There is a very easy way to fish mouth pipe that my buddy taught me. You can do it with your chop saw. Cut the pipe straight to start, then cut two angles so you have ~1/4" straight on the end, and two angles back at about 33 degrees. This should fit fairly well, use your grinder to perfect. (the measurements i gave are for 1-2 inch pipe, other sizes use faithful old trial and error:thumbsup:)
supermanotorious
Winchmaster 5000
New River, AZ
get the Harbor Freight notcher, it's cheap, especially with a 20% off coupon, you can put virtually any size hole saw on it to have a perfect mate with the other pipe
fourtogo
Tube notching
This was first way i was shown how to tubes. Drum sander to fit .
