Simon Thomas
Change of Screw
After lunch, I went to a hardware shop just now and purchased new sets of allen key screws. They are made of hardened steel (I guess because of the color). They will replace the stainless steel screws which I placed earlier on my rear axle shaft.
Reviewing the result of a few screws that came loose after trial run, I think I better replace them with cheaper screw and weld them. (do you call a thin weld as tig or tag welding?) This will prevent the screw come loose again.
Should I need to change or remove the parts along the axle shaft later, I just need to grind and redo the thin weld.
I will change this over the weekend and would like to see the result after that.
