Best welds thread :D
r_chez_08
Should be in the shop...
Cornwall, UK
One of my best with an arc welder, 2.5mm rod and 130 or so amps.
Shame the start and finish arent that good.
Bluethunder3320
i hope my welder survives the hurricane..... i should have brought it inside.....
ive got a big tarp over my stuff with 2 tractor batteries, a bunch of tires, and rocks holding it down.
this is gonna be interesting.
Ropertractor14
Fritzy Canuck
NS, Canada
Three of my school projects. The first two were done with tig. Open corner vertical and a vertical lap joint. Last image is of open corners done with flux core. Top and bottom flat position, middle horizontal position.
r97
Measure twice cut once
Massachusetts, USA
will add this in too, some pretty awesome welds!
http://www.diygokarts.com/vb/showthread.php?t=6821&highlight=welds&page=7
maybe i will take some pics of welds done with my new Hobart MIG welder! (finally got a gas bottle (expensive!)). maybe try out some aluminum too, and try some multi-pass on 1/2" (this thing is powerful!). really i just want to try out as many welding methods as possible.
Bluethunder3320
sooooo luckily the hurricane wasnt really much... other than the wire unwound a little my welder is fine.
i still have to test it but im pretty sure its all good.... haha. then ill go do some welds and post them up.
nak18
Atlanta, Ga
Well here is my first weld and best weld.
My first weld 10/6/2011:
Wanted to get a picture up without starting a new thread.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Your moving too fast and jumping around too much. BTW, careful with the fumes from that galvanized pipe.
nak18
Atlanta, Ga
I just tried it out, just to get used to the sparking and what so ever. Didn't try a real bead or anything.
I stopped after the splatter started getting inside my helmet. I had a soldering iron flash back after a bubble of solder popped and hit my face and hand. Luckily the ones that hit my face weren't hot.
I was welding outdoors and the wind blew the fumes towards my rightside. Fumes shouldn't be my problem, since I take extra precaution on it anyways(Melting plastic and soldering). Anything that melts above body temp, need to have protection against. :D
machinist@large
West Michigan, 49331
2 problems with this weld; both parts are galvanized (hot dipped in molten zinc) and the elbow isn't steel, it's cast iron. Steel and cast iron can be welded together, just not with the equipment you've got at the moment. Get some more appropriate matl. and you'll enjoy some much better results.:cheers2:
