clone ungoverned?
redsox985
PA
As long as it isn't jellied napalm gas sludge or old, it shouldn't matter.
redsox985
PA
well the capital "NO" made me think something bad might happen.
Nope, higher grades are just for higher compression engines so that the gas doesn't ignite early from high compressive forces, causing engine "ping" (IIRC). Really only applies in cars with higher performance engines. The larger jet just allows MORE gas to flow.
kendelrk
redneck engineer
westland michigan
well i just bought some new fuel line and a plug, just for the heck of it after cleaning out the carb, i went to put it back together, and the hose is way to big, and its letting it drip out of the hose, if i used a peice of the old fuel line, maybe an in line fuel filter to the main gas line, would it would well?
Try it. Oughta take you about 2 mins to find out.
kendelrk
redneck engineer
westland michigan
no way it will work, the hose it to thick, so im going out to the hardware store to get some of the right size fuel line, if this dosent correct the problem, what size jet should i go with? im at 90 now
EDIT: i bought a new plug. just for the heck of it, and to my suprise the plug wasnt very white at all, more black like carbon, so i dont think it was running lean, maybe rich? and heres a pic of the engine and my throttle linkage and sorry for the low quality photos
redsox985
PA
I believe that black is rich. But also, put a filter on that intake when you run it.
kendelrk
redneck engineer
westland michigan
there is a filter on when i ride, the filter is off because of having to lossen/tighten the carb bolts,
edit, i just did what you said russ, poured in some gas,and started her up, rode it around a bit off the choke, no choke at all and it was fine, but then it started to stumple when given gas kinda like my tecumseh, so i pulled the plug, and heres what i seen
kendelrk
redneck engineer
westland michigan
just pulled the carb, hooked up the gas tank and checked, i know the gas is getting to the carb, but its not coming out of the carb, , fuel shut off valve?
edit, i just put on an old carb, that got burnt in a fire and has no parts really, and hooked it up, fuel is coming through but not on this one,
kendelrk
redneck engineer
westland michigan
russ gets point for running lean, but blue won because he told me what was wrong with it, i was getting no fuel flow to the carb, drilled it out like he said, and now my karts running perfect
