Russ2251
AZUSA:Powered by LAWN-BOY
Definitely lean, lean, lean.
Check that float level...adjustable or not
Bring everything back up to stock to see if prob persists.
what about the stock jet?
This was (respectfully) a mistake. May have been a defective engine to begin with.this one i pulled out of the box put on all the things i had on the other,
Always make absolutely sure that a stock engine operates as advertised BEFORE making any mods.
Also, do mods one step at a time. Check out performance with each change. If satisfied with results, then go on to next step. Any mods should be reversible.
Right now, you have no idea where you are.
I always save old parts just in case.
