clone ungoverned?
its on my kart blue, i walked around and burnt myself, and choking does help, it has high flow air filter and exaughst, and a 90 jet it helps to have the choke about half, but the biggest problem is that i just blew my tire
The blown tire is not your biggest problem. Your biggest problem is that you gotta ride around with your choke on.
Yes, folks- I ride year round. The ice and snow are a blast. I've had it out in 10*F. 1-pull starts. Gawd I miss my GX340. *sniff*.
Bluethunder3320
i think engines like cold better. especially tecumsehs.
as for clones im not sure. mine still seemed to start up OK in the winter... just took a little longer to warm up.
Russ2251
AZUSA:Powered by LAWN-BOY
Running with choke on causes a couple of problems.
Pulling oil from crankcase (past rings) is one of them. Could be equated to reverse blow-by.
Given enough time, cylinder wall will destroy itself.
dave1701
Good for 100,000 Miles
MICHIGAN
Bluethunder3320
maybe its even lean.
experiment with the stock jet. aka. make it a little bigger until it runs right.
Russ2251
The only thing a so called "high performance" filter can claim is its ability to last longer under adverse (read dirty) conditions.
In other words, it will last longer between needing to be cleaned or replaced.
Pipes will increase hp a few percentage points but will have no effect on what the engine can or cannot pull in.
Intake valve opens...piston goes down.
Exhaust valve opens almost 2 revolutions later.
I did not have to re-jet either of my clones.
