Good news T-Man, I found all the parts and the tie rods. I will have to send 2 boxes for the tires are so big. Total cost for BOTH boxes $41.
I like to see what I am buying so I took some pics. As you can see the tires are like new. All parts are in working order with good bearing and what not. Just will need to be cleaned and painted. Complete every thing you will need down to the o-rings for the wheels. You have the shocks and wheel already from my last box. I also tossed in a Ody skid plate. You can see the round cut out. That sits up next to the from main bar protecting the tierods and pitman arm. The tires are the baloon type that take a lot of bumps as well. They go over anything so to speak. This setup is heavy so I think it will work well on a kart. More lbs up front the better. Total weight of both boxes is like 67lbs. The J-arms are way over built, Probably for a reason though. Ody's can pretty much take anything all day long. You will never damage on Ody spindle. King pin design like small cars. You will bend the main bar before you bend the j-arm or spindles.
Your going to have a moshing kart friend. This front end will be rock solid on a kart. All painted up and sitting on a kart will look mean. I can see it now. You can make a square frame. Then make a really cool looking roll cage. One like my blue Ody or something. Ya man... Till Cody it's a Dune Buggy. LOL
At a later date I can send you rear tires, wheels and hubs if thats what you want to use. with these front tires your going to have to use a larger rear wheel to match. I have a bunch of 50% tires to match the front tires I am sending you. You will have to make a hub though. Ody rear hubs are cast and splined.
You will need bolts for the wheels. And some cotter pins to complete this front end setup. You will have to find a thick walled main bar as well.
Oh ya do not forget the bonus items I like to send. You never know what I can dig out of my shop. $40 is a lot of money. But look how much your saving in the long run. And then look at the setup. I have no problems holding the parts as well. when ever you want them there yours.
Some pics
Edit: I just tossed in some Ody seat belts.
