18hp Briggs
It was submerged in carb cleaner for about a week then rebuilt.
Your main jet might still be slightly plugged up. You'd need to poke a small strand of wire or something through its orifice to be sure its completely clear.
If you've got a can of carb cleaner with the little straw, you could try spraying a little around all your carb and intake gasket areas while running. If you detect a sudden change in rpm that'll be telling you its leaking/drawing in air.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Last update for the night we never got it started and it turned out there was gas in the oil so we did an oil change still got nothing we did a compression test on the engine it put out about 65 to 70 psi which was good I'm just running out of ideas my brother is gonna talk to his shop tomorrow but I just want to get some ideas to try. We also tightened the head bolts which were a bit lose but again nothing.
65 to 70 psi is marginal, in my opinion. It should be well over 100 psi. In addition to the low compression & the fact that it won't run off choke, if you have fuel in your crankcase that means the rings are dunzo. Try a wet compression test (ie; a squirt of motor oil down the spark plug hole) to confirm this.
When doing a compression check, bear in mind that most modern engines have a compression-release feature to make starting easier. This will throw off the numbers. Test compression by rolling engine over backwards to get an unaffected reading.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
:iagree: Much thanks to anderkart for this method. a socket wrench on the PTO bolt works great. Turn the shaft slowly until you feel the compression and then turn hard & fast. Do it a few times for a good reading.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Oh also while researching the compression for this engine I've read that 70psi was good for this engine any thoughts on this?
I'd like to know where you read that. Think about it this way: A 70 psi compression reading roughly equates to a 4.76:1 compression ratio (70/14.7). A quick googling resulted in a very general statement on the Briggs website that "L-head engines use a CR of 6:1" which calculates to 88.2 psi. Big difference, no? Keep in mind these are very rough ballpark calculations that don't take into account valve timing, clearance volume of the cylinder head and altitude (I assume the engine is at sea level).
In my personal experience, compression readings approaching 60 psi will barely support combustion. The machine may still run, but not well, and not without pig rich jetting (which explains why your machine won't run off choke).
element10554
Glen Mills Pa
http://www.mytractorforum.com/showthread.php?t=61824
That is just one of the threads I read it in. I also see a comment about flatheads don't have much compression and I was told this was a flathead engine. Again any thoughts?
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Trippy man. Those tractor guys are funny :p Everybody said something different! Did you notice though that most dudes who sounded like they know what they're talking about mentioned the compression release making it impossible to get a good compression reading? There was also the little excerpt from the Briggs manual that user larrybl posted, I hope he doesn't get mad at me for reposting his stuff:
larrybl @ MyTractorForum said:
Quoted from the Briggs repair manual....
Check Compression
Briggs & Stratton does not publish any compression
pressures, as it is extremely difficult to obtain an
accurate reading without special equipment.
It has been determined through testing, a simple and
accurate indication of compression can be made as
follows:
Remove both spark plugs and insert a compression
gauge into either cylinder (one cylinder at a time). Turn
engine over with engine starter until there is no further
increase in pressure. Record this reading. Repeat
procedure on other cylinder and record that reading.
The difference between both cylinders should not
exceed 25%. More than 25% indicates loss of compression
in the cylinder with lower pressure. See example.
Example:
Cyl. #1 Cyl. #2 Diff. % Diff.
Eng. #1 65 PSI 60 PSI 5 PSI 7.6%
Eng. #2 75 PSI 55 PSI 20 PSI 26.7%
If compression is poor, look for –
1. Loose cylinder head bolts
2. Blown head gasket
3. Burned valves, valve seats and/or loose valve
seats
4. Insufficient tappet clearance
5. Warped cylinder head
6. Warped valve stems
7. Worn bore and/or rings
8. Broken connecting rods
Cylinder Leakdown Test
The cylinder leakdown tester, Tool # 19413, may be
used to test the sealing capability of the compression
components of each cylinder and quickly identify the
problem component.
Cylinder Balance Test
If the engine is hard starting, runs rough, misses or
lacks power, perform a cylinder balance test to
determine whether both cylinders are operating to their
full potential.
As far as flatheads having low compression, that's mostly true (yes, your twin is a flathead, aka "L-head"). The nature of the design is that there is a lot of space above the piston when @ TDC, so compression typically suffers at the expense of flow.
To make a long story boring, since your engine is a flathead and your compression may or may not be good what's stopping you from removing the cylinder head to have a look at the cylinder walls? You may find something you didn't know you were looking for ;)
element10554
Glen Mills Pa
I am not that familiar with engines so that is what is stopping me. I would not even know where to start when taking it apart nor would I know what to look for when I got inside.
element10554
Glen Mills Pa
Ok assuming I did something wrong I went up and did another compression test I made sure the throttle was open and hit the start button turns out I have 111psi in one cylinder and 116 in the other. So assuming it's the carb and it has new jets.... Something still might have clogged it?
Yes the main jet could be dirty already unless you installed a good in-line fuel filter.
Did you try my quick easy test for leaking intake gaskets in post #41 yet? That would also explain why you'd need to have the choke closed to keep the engine running after its warmed up.
Are you absolutely positive those new jets are the right size for your engine? If they made a mistake and sold you smaller ones you'd end up with these same symptoms too...
A low float level adjustment could also be causing this.
Needing to keep the choke on after the engine is warmed up typically means your engine has an extremely lean air/fuel mixture. And that's caused by either not getting enough fuel for some reason, or too much air from a situation like the intake manifold leaking.
element10554
Glen Mills Pa
I am doing the carb cleaning method to check for leaks ad we speak but I do not know if they were the proper size jets. Basically I dropped the carb asked them to fix it up was told it got all new gaskets rings jets and had been soaked in carb cleaner for a week
element10554
Glen Mills Pa
Also on a side note fearing that I may have messed up the compression test on my other 6.5th Briggs engine I was wondering how exactly do I do a compression test with the ohv release?
element10554
Glen Mills Pa
I sprayed around the gaskets of the carb and had no change in it's idle speed. So I guess my next choice is to take apart the carb and figure out how to adjust the float level
element10554
Glen Mills Pa
Does your intake manifold split off to both cylinders and have 2 more gaskets at each end?
If so, be sure to check those too...
Oh man Ive been reading off my iphone and I missed the part about doing the intake to. Ill try that tomorrow as I am currently at work till midnight. If possible though throw out any ideas that you guys might have. If this fails and there are no more ideas I am gonna attempt to take the carb apart and see if the jets are clogged or if the float can be adjusted.
