18hp Briggs
element10554
Glen Mills Pa
Again any help is greatly appreciated I have already connected the thick black wire that has the green white and black running through it but I am really unsure on what else to do or what is what.
element10554
Glen Mills Pa
what? can you draw that? lol, or post a pic of it? im confused.
Sorry for the bad drawings I believe the red wire from the starter connects to the red wire thats coming off the solenoid? but Im not sure where the black wire from the starter goes? Maybe it connects to the prong thats on the solenoid? Then there is another pair of wires the black and red that have an adapter the black is running up to the engine but I am not sure where the red connects thats hanging off the black??????
Your old wiring is a mess and I can see how it would make this all seem much more complicated than it really is. For now, dont try to make sense of how the old wiring was connected and just get an understanding of what these 2 switches need to accomplish.
Your stop button just needs either one of its 2 wire terminals wired to a ground source. (any metal part of your engine or kart frame would be just fine) The stop buttons other terminal just needs to connect to that single wire you found exiting from the inside of your engine. (that wire is coming from your engines Magneto) The engine will run fine with out this wire even being hooked up, but if your stop switch sends a ground signal to this wire, It'll simply function as your kill switch to shut the engine off.
Ok your starter solenoid has 3 connections:
One for the battery cable going to the positive battery post,
Another one for the battery cable going to the starter,
And finally that small push-on spade connector that simply needs to connect to either terminal of your start button.
The start Buttons other terminal just needs to be wired to either end of your battery's positive battery cable.
Your starter solenoids mounting bracket needs to be grounded for the solenoid to work. This is usually accomplished by mounting the solenoid to the engine or go karts frame.
And the last thing is your battery's negative battery cable should be attached to a metal part of the engine somewhere.
So to sum it all up:
The stop button simply needs to send ground the engines Magneto wire to act as your kill switch.
And the Start button needs to send power to the solenoids push-on terminal to make your starter crank the engine over.
You could probably re-use some of that old wiring if you want. I know wiring can seem complicated at first, so let us know if you dont understand any of these instructions :thumbsup:
element10554
Glen Mills Pa
Ah ok this deffinetly helps out but I still have a few questions. Reffering to my diagram the red wire from the starter button has to link to the red wire coming off the postive side of the starter solinoid?
Then the white wire also coming from the starter button has to link to the tab that is on the starter solenoid?
Then for the stop button the green wire mounts onto the top of the engine in one of those two spots. So the black wire with the tab adapter links to?
So sorry if any of my questions have already been answered I am just trying to make sure that everything is correct before I wire it up.
Yes, and using that in-line fuse in this wire is a good idea
Yes
The black wire needs to be attached/grounded to any metal part of the engine or kart frame. The green wire needs to be connected to the magneto wire you found under the dead leaves in your video.
element10554
Glen Mills Pa
Hey thanks again for the help I believe it is all hooked up im waiting for a throttle body for my carb and my fuel pump is being rebuilt at the moment so when those are done I am going to see if it turns over :) I was also lucky enough that my grandpop has a brand new ATV battery lying around so he is willing to just give that to me.:thumbsup:
element10554
Glen Mills Pa
Ok I am currently trying to start my engine and I'm not sure it's getting fuel the engine starts with carb cleaner being sprayed into the carb but not on just fuel is there a diagram on this site that shows how to hook up a fuel pump? It only has 3 holes sticking out of the pump also do you guys have any other suggestions?
Forgive me for not re-reading everything- been awhile- Is that an 18hp Briggs Vanguard V-twin? If it is, gimme a bit and I will go check mine...
element10554
Glen Mills Pa
Im not to sure if it's a vanguard it's an old craftsman Briggs twin cylinder flat head engine I'm assuming the fuel pumps won't be to much different
Okay- so three ports, right? one in, one out, one vacuum. I don't know if the arrangement has changed much, but give me about 15 minutes, and I'll see what I can find out for you...
EDIT- headed out with a flashlight-
My briggs pump is an oval-shaped affair with three ports-
The middle port is the vacuum connection
Left of the vac line is the fuel line to the carb
Right of the vac line is the fuel line from the tank.
element10554
Glen Mills Pa
Last update for the night we never got it started and it turned out there was gas in the oil so we did an oil change still got nothing we did a compression test on the engine it put out about 65 to 70 psi which was good I'm just running out of ideas my brother is gonna talk to his shop tomorrow but I just want to get some ideas to try. We also tightened the head bolts which were a bit lose but again nothing.
element10554
Glen Mills Pa
So I got the engine started today but ran into yet another problem. It seems as though the engine will not run off of choke. I was wondering if anybody had any ideas to remedy this?
