Hi all, Greg-O here, needing some help on my engine. I got a gx200 Honda, not a clone, and i took out the governor assy. and now dont know what to do with the governor control on the carb, it just sits there. Do I need to fasten it wide open, shut, or somewhere in between? Do I just need a mikuni or can I stick with (new) oem carb and modify the governor control on the carb? also, i honed the engine block and put some new rings in it with a gx160 head and thin gasket for higher compression, new valves seated, and the thing will dang near rip your arm off on that compression stroke. any help is appreciated yall.
thanks..
thanks..
