gear ratio
vgk
Las Vegas, Nevada
Are you planning to go fast or slow?
With a clutch a good gear ratio is 6:1 or 5:1 or lower if the kart is heavy.
Break out your tape measure, and measure from the ground to the top of the rear tire. Then tell us that measurement, whether it has a clutch or CVT, an engine type. Then, count the teeth on the clutch or CVT driven unit, and on the rear axle.
The entire height of the rear tire is 6 1/2 inches? Are you sure? What's the size marked on the sidewall? Need the other info I requested, too.
pooh3700
i live in nashville tennessee
yea its six and a half ,it has a clutch, and has a briggs and stratton 5hp fun power, the clutch is a 10 tooth and i dont no the number of teeth on the sprocket but thats what i want to change
Well for starters, I need to know that if you'd like an answer- it would really help to know what you're dealing with. What's wrong with current performance?
What size rims are those, anyhow?
Okay- lesson one- A smaller rear sprocket (like you want) creates a higher gear ratio- Result? SLOWER take-off. LESS torque at the wheel. Again, please count teeth.
Russ2251
AZUSA:Powered by LAWN-BOY
pooh3700
in no what the diameter is but i was thinkin about my black go kart but the red one is about 10 and a half inches tall and i am not doing all that stuff just to count some teeth on my chainwheel why cant you guys just tell me a good gear ratio
