Flywheel explosion evidence
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I've been wondering that for a while. I assume that you, too want to know if vae float risks a piston strike?
Yep. I suppose you could do a "redneck test" by removing the cam and reinstalling it so that one of the valves will open with the piston at TDC. Im sure Russ probably knows though:thumbsup:
My crankcase is staying "open" until my new gasket set arrives. Maybe I'll try that. gently, of course. And only if nobody here knows for sure.
devino246
Lynchburg, VA
Although at operating temps, with parts expanding from heat and centrifugal force, the fit may be slightly different.
Speaking of gaskets, looks like Ill be getting a new head gasket for mine, seeing as im only reading 15psi of compression.
Ooh- That's a bit weak!
Regarding valve float, could there be a collision in a clearance engine? I'm wondering if the valves could bounce past the normal opening distance enough to strike...
sideways
Unfinished projects king.
Perth, Western Australia
I replied, argumentatively. Argue with me on there, that should get them at least a little bit interested. ;)
Disclaimer: Everything I said was complete BS, I believe the opposite to everything I said.
Thanks
Hayden
sideways
I'm pretty sure they aren't interference engines, take the rocker cover off and push the valve down as far as you can while it's at TDC, if it hits the piston then there's a fair chance it will hit in normal operation.
Thanks
Hayden
Bluethunder3320
i saw that toystory said they would explode.. so i was like total BS lol.... haha... well thats still what i think.
devino246
Lynchburg, VA
:roflol::roflol: my post has to be reviewed by an admin because I used the "trigger word", "idiot".
WTH??,
You have not been given the permission(s) to access this page. You require the following rights to view this page: 'Edit/Delete Own Posts'. For a full list of permissions you have on this community, please visit your Personal Zone Permissions page.
Lynx_Genisys
Alberta, Canada
the only fly wheel i've seen grenade is the one in m 91 Talon..
I bought it blown up.. got it for 700$..
there was about 1.5inches of the bell housing left that still contacted the engine block.. lol..
you hear about clutches literaly blowning up all the time, but its rare to see, even in hi-performance drag cars, n over done "Street cars" etc.. (or at least from what i've seen.. usualy when catasrophy strikes, its far worse than a simple clutch grenading...)
guess thats why they sell "tranny blankets"
and ppl joke about tranny baskets to catch the parts.. it realy does happen..
I know around here, any drag/street car that runs under 10 seconds is required to have a tranny blanket otherwise the wont let you run...
but i've never seen it happen on small engines such as common for karts etc till now!!!
If your engine has a built in compression relief feature that's probably normal. On GX/clone engines I've heard of guys spinning the engine over backwards to defeat the compression relief and getting a more accurate compression test.
devino246
Lynchburg, VA
Thats what I was thinking, but I tested our 2 briggs lawnmower engines a few months ago and they both read over 70. Wouldnt they have compression release too?? Plus, i just tried a wet ring test, poured some oil in the sparkplug hole, tested it again. Got it to read about 50. So Im thinking bad rings, which I happen to have a new set of anyway.
I'm not sure what lawn mowers have them or not, but if a wet test raised your readings it does sound like your rings are failing to seal. (either that or the cylinder walls had just previously been washed clean of all oil from a major carb flooding issue or whatever)
sideways
It's more likely the volume of the oil you put in that made the difference, as well as sealing everything a little bit better.
Thanks
Hayden
