I'm in!
Hey Russ, are clone/Hondas interference engines??
I've been wondering that for a while. I assume that you, too want to know if vae float risks a piston strike?
My crankcase is staying "open" until my new gasket set arrives. Maybe I'll try that. gently, of course. And only if nobody here knows for sure.
You have not been given the permission(s) to access this page. You require the following rights to view this page: 'Edit/Delete Own Posts'. For a full list of permissions you have on this community, please visit your Personal Zone Permissions page.
my post has to be reviewed by an admin because I used the "trigger word", "idiot".
WTH??,
i saw that toystory said they would explode.. so i was like total BS lol.... haha... well thats still what i think.
Speaking of gaskets, looks like Ill be getting a new head gasket for mine, seeing as im only reading 15psi of compression.
If your engine has a built in compression relief feature that's probably normal. On GX/clone engines I've heard of guys spinning the engine over backwards to defeat the compression relief and getting a more accurate compression test.
Thats what I was thinking, but I tested our 2 briggs lawnmower engines a few months ago and they both read over 70. Wouldnt they have compression release too?? Plus, i just tried a wet ring test, poured some oil in the sparkplug hole, tested it again. Got it to read about 50. So Im thinking bad rings, which I happen to have a new set of anyway.
