Gtc/comet clutch problem
metalthrashinman
Hope, NJ
...sorry for yellin....and i'm really payin tension to all replys....now i know what to call the spring(garter).....one looks o.k...the other..something wrong...i did not purchase locally...so takin it back is out!!! I feel.i broke the thing. So i need to buy another one.... All i thing i need is to repalce the garter spring...and try again....as stated...followed the instructions(to the letter) my project was 50 miles away....rec.clutch one day....practiced on a spare block(installin clutch).....just brought my ride closer to home......had to do mods(to clearance) for torque verter....install hyd. Brake.....put in new eng/clutch fired her up..... And here i am....tryin to figure out how i screwed up....sorry you think i was yellin.....i'm just frustrated my plan did'nt go as i thought it wood......thanks walt
It's all cool, but how about answering our ?'s?
wall gator
TAMPA BAY AREA
That's too bad that you feel you can't return it, because either you buggered up the install or it's a warranty claim. Did you install that spring, or was it factory installed?
:mad2: BOTH WERE FACTORY DONE......WHEN I REC. CLUTCH,I CHECKED TO MAKE SURE I REC. ALL THE PARTS..READ INST. NEXT I INSTALLED ON SPARE BLOCK(TOOK A COUPLE OF TRIES TO GET IT RIGHT!) TOOK IT TO SHOP/INSTALLED IT (STILL CHECKING THE INST..JUST IN CASE LOL) AND HERE I AM....THANKS WALT
redsox985
PA
Caps lock is located on the left of your keyboard just above the shift key.
