wall gator
JUST PURCHASED A NEW GTC TORQUE CONVERTER CLUTCH FOR MY 6.5 CLONE ENGINE. MY QUESTION IS.....CLUTCH SEEM'S REALLY NOISEY (LIKE MARBLES ROLLIN ROUND IN A WASHING MACH)??????? I THOUGHT THESE CLUTCHES WERE QUIET????? ALSO, HAVE TO PROP UP THE REAR(JASCK STANDS) BECAUSE EVEN AT IDLE THE CLUTCH ENGAGES????? WHAT DID I DO WRONG?? (FOLLOWED THE INST TO THE TEE) AND HOW DO I CORRECT THIS PROBLEM????? THANKS WALT
sorry no pic's..new to this puter stuff!!! it's a gtc torque converter(new replacement for comet/ 30 series) pic's at gtcindustries.com.,,,,this is a real nice product...mount's to hoda/clone w/o mods.....it has the correct belt(203589)..simple to instal(followed structions)....will not disengag,while idle..seems to be engadged at all times????? make one hell of a racket????.....what do in need to do, to correct problem????
D.a.m....sorry should be GTCMANUFACTURES.COM
heading to shop now......all the parts brand new...all look's good(to me)....the driver and driven look o.k.....i havent disassembled either unit....goin to shop and try again..will post problem (if i find one).....thank's for all the help guy's....
JUST GOT HOME FROM WORK....AFTER PULLING..DRIVER..FOUND ONE OF THE SPRINGS(INNER) STRECHED OUTTA SHAPE????? I FIGURE THIS IS THE PROBLEM?? OTHER SPRING O.K.......WHEN HOLDING THE SPRING OUTRIGHT.ONE END GOES DOWN/THE OTHER END POINTS UP. I EYEBALLED THE DRIVEN///LOOKS GOOD TO ME//DID NOT DO A TEAR DOWN. THIS IS WAS ON A NEW ENGINE(STOCK).AND A BRAND NEW CLUTCH. HAD MY RIDE(TOP SECRECT FOR NOW???) UP ON JACK STAND(ONLY LOAD WAS AXLE(LIVE) AND TIRES....THIS CLUTCH WAS INSTALLED PROPERLY.....START ENG.(WARM UP 3/4 MINS.) MARBLE RATTLE FROM THE GET GO...COUPLE OF REVS(SEE CLUTCH FUNCTION)...I KNOW..SHOUDA SHUT HER DOWN THEN..BUT HEY!! FIRST TIME WITH MY MY TOY!!!! AS STATED NO LOAD ON KART WAS ON JACK STANDS!! SO WHERE TO GO TO BUY ME SOME NEW SPRINGS????? THANKS FOR HELPIN..WALT
YES....2 ONE LOOKS GOOD/THE OTHER APPEARS STRECHED OUT AND BENT. DID NOT SET DOWN BUT I DID TRY TO STOP WHEELS FORM SPINNIN (WAY WAY TO MUCH TO HANDLE) WITH THE NOISE AND NO IDLE(CLUTCH) NOT CARB. NO BRAKES INSTALLED AT TIME.. AFTER A FEW REVS WATCHING THE CLUTCH WORK(LOOKED GOOD TO ME) SHUT IT DOWN.....AND POSTED PROBLEM TO TRY AND GET HELP!!!!
