vd2021
- Messages
- 16
- Reaction score
- 0
vd2021, your not going to like what I have to say, but here we go.
The person that had it befors you took the whole thing apart . driver and driven and didn't put it together right.
The driven's spring is sprung they took it apart and didn't reset it.
Chances are that the driver doesn't have any weights in it, at high rpm the clam pieces will still spread and grip the belt creating the slow movement ... I bet that if you reved up your engine and the tires started turning you would be able to agresivly grab you rear tires and they would stop.
Take the bolt out of the driver to take it off, slowly take off the outside part of the driver and pull the two apart ( like a clam shell ) fold them open, put on a table and grab your camera and take a picture showing us both inside halfs. dont pull any thing out...... then post picture here.
Thanks. I'm trying to get a running go Kart for my kids and not spent a grand doing it. I'm only about $130 into it so far. I have attached a pic of the exploded view to help me as I am not familiar with some of the terms yet. I have had the driver apart to clean it. I used a rough and fine wire brush drill attachment to remove the dirt/rust. I still need to hit the part #12 with the wire brush a little more. All of the parts on the pic are a part of my driver. Can you use the parts view numbers to help me with your instructions for removing and taking pictures? I will take them this evening when I get home. Thanks so much for your help. I want to get it running but I don't want to buy a part/something I really didn't need because something else was the problem.
R/s
take the driver apart and take pics as you go.
