speed question
r97
Measure twice cut once
Massachusetts, USA
i was fidling around with the calculator and found out somthing. if you get a tc you can have the final drive rateo be 2 to 1 and hit 72. then have a low end of 6 to 1, which wont burn the tires but will get you up to speed. although you can do this DONT!, like kaptain said "I can hit over 70...however i would have to be insane." and by the way bike spedoes are good for karts
2:1? I don't think that's going to happen. Plus, dunno which TC you're referring to, but the Comet 40 low range is around 2.43:1. So with a 2:1 final, low range would be 4.86:1, which certainly wouldn't be anything to write home about in terms of launch. Based on my own experience, I really don't think that 2:1 final drive ratio is an option...
Kaptain Krunch
Pro Junk Collector
vermont
If you had 10" race slicks, and a flat road. 4.86:1 isnt horrible, and you would probably get moving. but for anything but asphalt and race karts, its not gonna happen.
That One Guy
Occational Annoyance
Pasco, Washington
I've been wondering about a spedometer for my kart actually. I want a gauge though. Is there any way I could go about doing that, and have an acurate reading? I was thinking a wrecked motorcycle gauge, but I don't know how to set that up for a lawn mower tire, instead of a bike tire.
Kaptain Krunch
Pro Junk Collector
vermont
motorcycle speedos are generally cable driven, and it would require a custom gearbox and a little math for it to work properly with mower tires. A digital bicycle speedo would work fine tho. there wicked cheap on ebay.
pkgocart
i mean 70k not miles plus im not worried about fliping my kart is wide as hell and i decided to use alot biger tires 19 in diameter in the dack what do you think
pkgocart
i mean 70k not miles and im not worried about fliping my kart that im building is wide and i have desided to use a lot bigger tires 19 inch diameter and im looking for top speed now i know my motor wont burn these tires
