home made hand/parking brake
r97
Measure twice cut once
Massachusetts, USA
hay all
do you guys think it would be worth fabricating a hand brake for my kart i gonna start building? i can make one for about $7 total. deos anyone ever use a hand/ parking brake:confused:?
thanks!:D
Big Boy
Noob!
New York
Would it be worth it? Yes and no. It'd be good for idling. If your kart tends to roll when it idles, then yes it might be. Or if you store your kart on an incline, also would be worth it. Other than that, I dont see much use for it.
redsox985
PA
For $7 why not. You don't know when you might need it and when you do, it'll be $7 well spent.
Big Boy
Noob!
New York
I dont think the price is what hes worried about. Probably more time consuming/work than its actually worth. Just a thought, of course.
If you can rig one cheap and easy, do it. Especially if you don't have electric start. There are enough of us out there that can tell you funny, scary, and sometimes quite painful stories of pull-starting a kart, and having it take off unattended. There are a few ways to prevent this kind of mishap, and a parking brake is one very good way.
r97
Massachusetts, USA
ok then maybe i will it only involves like to little welds a bolt some cable and like 2ft of flat bar. well thanks for the feed back =)
oscaryu1
:mad2:
redsox985
PA
But if you are comparing $7 to $3 I'd side with the simplicity of being able to come to a stop on a hill, throw the parking brake and step out without having to hold it still and drop a brick under the tires.
r97
Massachusetts, USA
i think i will make one anyway
1 i like making stuff
2 it would be some what useful
and 3 like redsox985 said it wouldd just be alot easyer
but thanks every one for the replys they were reatly apreciated. look for my project log i will b starting soon =)
Randy
How did it turn out?
I have been toying with this idea. The kart Im building is a small two seater. The brake control is on the far left side of the cart. I have a couple of small kids that I will be teaching to drive and I thought an E brake might be nice. Reaching the brake would take a few seconds because of the steering shaft being in the way.
