"Ziegenstall Motorenschmiede" presents The Vale Special ....been awhile 2025 edition
Bansil
Painter of gnomes....
@Denny this will show axle mount
Next was mockup axle and check clearances
I will have to Z the shackles for Frame clearance, I found out.
May have To clearance top Frame rail, won't know until I drive it, to many variables I have seen on line towards spring movement.
Tires clear at full lock like designed 👌
Front
Rear of tire at lock
Level is bottom of Frame, about 7in of clearance with no wt on it, plan to loose 2 more inches with seat.
So about 4in clearance when done
Last picture for today probably
:cheers2:
Bansil
Wife helped get frame out of ...cough....cough...spare bedroom. Going to set camber at 8 degrees back, and I should have 8 more to adjust. Best thing is if 8 degrees is too much, and can flip axle around and can go up to 0 degrees then.
No dogs, walls or Bansil hurt with wifes help.
Also plan to draw and cutout new shackles to clear frame rails today
Bansil
I just quoted myself 🤪
So leveled frame, set caster at -8* and welded in.
If you notice I set -8* at nominal adjustment so I can loosen 8 x 3/8 bolts and adjust it.
Lots of back and forth on interwebz about the caster to scrub radius with no camber...ya,ya,ya.....so I made it adjustable
And since I built everything symmetrical, I can do a 180* spin and start at +8* so plenty of adjustments are available 😉20210716_171509.jpg
Gotta program and cut new shackles now...
C-ya all in a bit
Bansil
Got home late as usual, clickity, click....post processor and I made pcs for backbone of rear skin/deck lid, 3 minutes and all parts cut, so nice.
Tons of cleanup and welding still, basically making my on "U" channels at angles. Hopefully all the pcs will be horizontal
Bansil
PROOF OF CONCEPT...CONFIRMED....kind of...needs tweaking :popcorn:
So mocked up skin frame attachment points.
Set pcs at 25* and clamped together
Neat....
Kinda lined up, got verticle and top 8" or so level....may have to fudge some.
So I have 3 surfaces flush and level....:popcorn:
The journey continues...
Bansil
So am going slightly askew, made some of these brackets to establish 25* and stiffen this thing up.
Started with paper and pointy thing that writes, start at top and scribble to bottom of page, next it was off to cad
Next mockup, the straight pcs will be seat back mounts
Worst thing is I am going to have to be very strategic moving forward :unsure:
With body support attached via welding, I can not get it into/out of current build space, corners and doors don't trig out 😛
Bansil
I mean the doors and hallway IN the house, I am going to clean out a lean to area this weekend and try to get paint on what I have done to keep rust from humidity down and start building outside
Bansil
Feels like I do so much mockup...with every one done, I have to make the next fit.
Tonight was proof of concept again, this time on rear angle, I do need to make another bracket, when I mirrored the part it didn't actually mirror it backwards, oops so Vale is backwards on one side, easy fix this weekend. I have the 1/2 drop built in.
Blanket is for photo contrast, since we dont own white sheets 😛
