yerrf dog flouds after its riden everytime??
Grimace
Mr. Furious
Word to that. Also, tyres?
Jk guys, we might be from different places, but we are all brothers in one way or another.
On another note, I know more about mikuni diaphragm slide carbs (like they use on the gy6) than I ever wanted to. I had a 78 Yamaha xs11 with 4 mikuni's on it and it only took me three years of tinkering, syncing, and adjusting to get them absolutely perfect. I don't do anything sub par or half arsed. If it ain't perfect it ain't right. That being said, any rip, tear, hole or distortion in that rubber diaphragm will cause problems, starting small and only getting larger. It is only 12-13 bucks for a new one and it will fix more problems than you think. Also, remove the float and try to "sink" it in fuel. Hold it under the fuel in a bowl/small bucket for a minute. If there is a hole in the float, you will see bubbles or the float will get heavy. Check the needle spring also, if it is weak, it will allow fuel past the needle even if the fuel level is higher than the float stop.
Snuffalupagus
Hey guys, I'm new here and found this forum and subsequent thread.
I'm having the same problem with my 150 yerfdog. I have replaced the needle, seat, and float.
It starts and runs fine for about 5 minutes, then it acts as if the float is stuck, and fuel flows from the overflow.
I am about to just buy a new carb. Any suggestions on a replacement?
I was considering the Mikuni Carburetor VM26-606. The yerfdog is stock and my 11 year old daughter drives it.
Thanks! ;)
Thanks! ;)
Are you sure that the carb is properly clean? There a lots of little holes that you need to poke out to make sure that they are free of dirt
Snuffalupagus
That's what is frustrating me. I just rebuilt a 1962 Code 38P Pontiac 389 v8, but I can't get this little Japanese carburetor to work right!
I've cleaned everything. Today I thought I'd give it another try.
Took of the carb, double checked the float for leaks, inspected the new needle and seat, put the bowl back on, and as soon as I added fuel, out the overflow tube it came.
I'm starting to wonder if something isn't catching on the float somehow. With the carb off the kart, I shake it, and can hear the float moving up and down. I put it on, and her comes the gas...
:surrender:
