yerrf dog flouds after its riden everytime??
dictionary6767
Nj
ok so my yerf dog flouds everytime it is ridden? but if I turn it on to idle it wont floud? Like 5 mins after it is ridden it will start pouring out? I clean it and it works fine for one ride then flouds, it gets really annoying!! what should I do.
dictionary6767
Nj
thanks for the replies. the rubber part in the carb not the float has a small rip is that a prob?
jamyers
Buffalo Gap, TX
Either your needle valve has trash in it, or your needle valve (or seat) are damaged and need replacing it, or your float has a hole in it and is filling with gas and going too low, flooding the engine.
You might also let us know what engine and/or carb you're talking about, some are more prone to issues than others.
Am I the only one who finds it funny that somebody with "dictionary" in their username has such awful spelling?
:roflol:
jamyers
Buffalo Gap, TX
It occured to me this morning over coffee (random stray thoughts, lol)...
If that diaphragm was torn, wouldn't the mixture needle stay down, resulting in a LEAN condition, instead of a rich (flooded) condition? Or is it the other way around?
EDIT: did some googling and re-found this pic showing the operation of the diaphragm which confirms my thinking that he's actually got a lean condition at best, and at worst the slide / needle aren't moving up at all, starving the engine...
dictionary6767, what exactly are the symptoms you're getting?
Not to argue- as I thought the same thing- there is the possibility that the slide was stuck in the open position, possibly caused by the damaged diaphragm binding. Could still be a float/valve issue, too.
Jamyers- Am I gonna start seeing royalty cheques for that signature?:toetap05:
:roflol:
