Would you trust a crankshaft...
oscaryu1
...that was rusted to hell, and then loosened up with reverse electrolysis?
oscaryu1
The crank is $127 new. Motor's were made in the 80's, it barely exists. Zenoah G2D 22.5cc.
oscaryu1
It moves a person. Spindle drive.
I know it's almost as new engine, but I like these engines. Reliable.
I'll post up pics, it doesn't look good but feels solid, no play on the bearings.
oscaryu1
oscaryu1
#1 Before electrolysis, bearings on crank seized to that position.
#2 After electrolysis, bearings loosened up.
#3 I know, I'm not going to use that piston.
jr dragster T
Cold place
Most likely that crank bearing will not be salvageable but scotch bright works wonders on the rest of it. Going to have to flush that big end bearing REALLY good.
freakboy
the names 'mater
hick town
U got small bore and tiny stroke! LMAO ahahah i knew rc car pistons are smaller then that but thats just pathetic.
02mx-5
Orange County, New York
he did see how small the pistons are, theres a picture right there. Also, i bought a brand new goped engine awhile ago. I used it for about a month and then the crankshaft broke right in the dead center. It didnt explod and go everywhere, it just stopped working and made some great sounds while doing it. I would just replace the piston and go for it. My point is that they can break new or old. ALso, do you use a 3rd bearing? the one on the spindle? If you dont, then get one. It will prevent the crank from breaking
oscaryu1
Yeh, I'm uploading a picture l0lz.
Crankshaft doesn't break unless something actually forcefully breaks it. Sounds like either you weight a couple thousand pounds :p, or you didn't adjust your EPW correctly :)
I run all my motors with 3rd bearings, I don't want my mounts to bend/flex.
