Wont start
Jm053084
Missouri
So I got a 6.5 Greyhound engine I took out the Governor from the inside of the motor I relined the shaft from the. To the. And I still can't get it to start up what did I do wrong
Dirtracingchamp
Connecticut
Have you tried starting fluid?
---------- Post added at 01:44 PM ---------- Previous post was at 01:43 PM ----------
If you have, check your valve lash. it may have gotten screwed up when u were fiddling inside the engine.
anickode
S.E. Michigan
I've heard of a few cases where people did the governor removal, and when they pulled the cam, the pushrods slid back far enough for the lash caps to fall off.
Pull the valve cover and check everything out.
Jm053084
Missouri
Yes I pulled the valve cover off and check the rocker arms and all that stuff the rods only new place like it should be I make sure I was at top dead center. I'm not sure how true this is but I was told there is two different types of top dead center compression push out and I forget the other name of it is this true
65ShelbyClone
SoCal
No, it's not true. TDC is when the piston is at the top of the stroke. When you're putting it back together, it doesn't matter "which" stroke as long as you get the marks aligned.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
It doesn't matter lining up the dots on the crank and cam.
But it needs to be TDC on the COMPRESSION stroke to check or set valve lash. The "other" TDC is exhaust.
anickode
S.E. Michigan
Yup. Up is up, down is down. The piston doesn't dictate what stroke the engine is on, the valvetrain does. Marks aligned = good to go.
Once the engine is assembled and timed, the Piston does hit TDC twice per four stroke cycle. Just before the power stroke, and just before the intake stroke.
If your timing marks are aligned, then it's right. Something else must be wrong.
TDC of Compression. Both valves are closed. Lifters are sitting on the cam base circle.
TDC of Exhaust. Both valves maybe open. Lifters on lobes.
Set lash when the lifter is on the base circle of the cam.
Jm053084
Missouri
so I tried again I figured it was 180 out in the timing dots are a line put everything back together check the valves all that good stuff got good fire but it's hard as **** to pull the Rope to try to start it now any ideas on that maybe I have it at the wrong stroke
---------- Post added at 08:59 PM ---------- Previous post was at 08:29 PM ----------
Update lol it runs again. Kill wire was pinched
