its a brigs 5 or 6hp 190cc vertical shaft engine. Cast iron bore comercial spec etc. Has red metal cover. Not sure how old it is..maybe 4 or 5 years
Im finding these days i have to top it up everyday(didn't have to do this in the past). Its not smoking at all, the crankseal isn't leaking...is it just a bit worn out?
have put in new oil but that didn't change anything.
should i wack some new rings in it? or will i have to rebore and fit oversize piston etc?
i have never had to open up a briggs before so have no idea.
any advice would be choice
cheers
cheers
