Why is my engine using oil?(more than normal)
sexyvicta
its a brigs 5 or 6hp 190cc vertical shaft engine. Cast iron bore comercial spec etc. Has red metal cover. Not sure how old it is..maybe 4 or 5 years
Im finding these days i have to top it up everyday(didn't have to do this in the past). Its not smoking at all, the crankseal isn't leaking...is it just a bit worn out?
have put in new oil but that didn't change anything.
should i wack some new rings in it? or will i have to rebore and fit oversize piston etc?
i have never had to open up a briggs before so have no idea.
any advice would be choice
cheers
Bluethunder3320
is there any oil coming out of the breather?
no leaking gasket?
could be worn valve guides or bad rings. any bit of oil appearing around the head gasket?
sexyvicta
i will check breather. I was thinking if it was coming out there it would be smoking a little??
cant see any oil leaking out of anywhere
Bluethunder3320
try using something just a little thicker. i dont know whats reccomended for that engine, but most i have seen just use 10w 30.
sexyvicta
recomended is monograde sae30 im pretty sure. Thats why briggs oil is sae30.
Dont think the oil itself is the problem as i've always run it on sae30 and only now it is starting to use oil. I do have access to sae50 aviation oil but yeh would rather solve the problem than mask it with thicker oil
Bluethunder3320
check around the head for a little leak in there. also check the plug. if its all burnt and crispy then its burning oil.
if you have a compression tester check it.
sexyvicta
will check again for signs of oil use.
yeh my comp tester stopped working ha. Should go get a new one
sexyvicta
whats a healthy compression reading for an engine like this?
will borrow my friends tester
Bluethunder3320
im not sure, someone else may be able to tell you.
it MAY have a decompression thingy in the camshaft, so turn it over backwards.
karl
North east Ohio
Anything below 100psi should get re-ringed. I think at 60pis it will not start. You can run it at 80psi, but you will lose power and burn oil.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
What type of engine are you thinking of?? I tested my Briggs lawnmower when it was brand new and got 60psi. Tested our old one and it was 80 (carbon deposits).
sexyvicta
hmm ok i will test and report findings. You sure this thing has a decompressor??
compression cant be too bad. Starts first pull. Hot or cold.
