parts for the hondas should be fairly identical.. both are technically big blocks already,
both ends of the same scale so to speak
And yes'ish the GX390 is the role model for all similar sized clones..
Rato makes both, the 390 and the 420 which you find relabelled as predator at HF.
And many parts are shared between the two.
(keeping the costs down and such)
the bigger combustion volume comes from a slightly bigger bore and stroke (GX390 is 88x64 mm just like the R390 and R420 is 90x66 mm so a two mm increase in both directions
why? because it's cheaper to increase the bore slightly and save on crankcase material more than you'd need to spend for the increased piston size.. and the crankshaft is likely cut from the exact same blank.
btw rato makes a true clone (196cc);
the 210 (212cc) and a 225cc
as well as the 240 and 270 gx clones and a 440 cc to top out the gx390 case size...
And yes.. the least likely it is an engine gets used for racing, the least likely it is to find aftermarket performance parts for it.
the gx390 is about the most modified enigne right after the true clones
(don't forget: anywhere in the world but the US the 212 is basically a niche product and everyone's going true clone really... very slowly single 212 225s are coming around (thanks to Tilly mostly))
Nevermind.. GX390...
the engine is the base of all mini nascars soem junior dagsters and whatnot,
modded to push up to 45hp
(and no, you can't in your homeshop I'm afraid)
So chances are you'll be able to find whatever performance part you might need.
the smaller GX270 however might prove to be a tad more difficult.
sure some gx240 parts fit, and even some gx390 parts do..
but it's essentially too small for a big block and too big for a small block
to take a noteworthy share of the tuning parts.
great engine, don't get me wrong..
but if you want a good coverage with tuning parts.. the gx390 is about as good as it gets.
#40 is okay.. if you have #41 sprockets I'd recommend swapping to 420 chain though (much much beefier chain, same size sprockets as #41)
