Which engine choice is best?
DixieRect
I have a manco silver fox and I do a lot of trail riding, all types of terrain. I've been trying to decide which engine to use, an Animal or similar box stock engine with 10-15hp or this duro max 16hp I found online. Also, dependability is a concern...
Thanks for your help
It's pretty hard to go wrong with a big brand name. I can't speak to the Duromax (which I think is of chinese origin), as I have no experience with them. Are you purchasing new?
DixieRect
Yes, brand new. My biggest concern is, the animal is more of a race motor and the duro max is work motor (concrete mixers and such), will that matter for trail riding? I've done some research on the duro max, is a Honda clone and they say reliable. Would you say the animal would out perform it, even though it has less hp?
The first thought that comes to my head is that an Animal is likely engineered to rev higher. While, with the right gearing that may be of benefit to you, I have no idea what the low-down torque numbers might be like. For the trails, I think I'd be inclined to go with the big-block. The fact that it's a "work" engine, does not detract from the potential performance or reliability. Easily 90% of the engines we use on this forum are of the same type.
For trail riding, you'll want to consider a CVT, such as the Comet 40. It really will maximize what you can get out of your engine. Also, powertrain goodies like CVT's and clutches do tend to be more expensive in the 1" shaft size than the 3/4" shaft size.
DixieRect
Those were exactly my thoughts and my next question was type of clutch.
Also, I have been considering snowmobile engines, how do you think they would work as far as cooling goes, without getting into liquid cooling?
2-stroke? the word is that they work fine in summer conditions as long as they are jetted correctly. I don't know how trail-friendly they'd be, though. The engagement RPM can be fairly high. Geared right, the wheel speed will be fine, but the sound might be obnoxious.
You also need to make sure that all aspects of the chassis can tolerate a sled engine's power, too.
All things being equal, I'd go DuroMax combined with Comet 40 CVT.
DixieRect
2 or 4, but I'd imagine you'd have to mess with the jets quite a bit. I think I'll take your advice and go with the DuroMax and the 40. I appreciate your knowledge, thank you
jamyers
Buffalo Gap, TX
I'll second toystory's words.
A 10-12hp Animal or Box Stock Clone is a high-winding race version of a 5-6hp engine that won't make much more torque at lower rpm than a base 5-6hp version.
A 16hp engine will be loafing along, making a lot more useable power across the rpm band, and if you want to you can mod it for higher rpm and make even more.
DixieRect
I will post an update, but its a work in progress, Subaru 6.5 will be in till spring. Thanks again Jamyers and Toystory for your advice!
Kaptain Krunch
Pro Junk Collector
vermont
Im a huge advocate for sled/bike engines, simply because of cost. and the fact that im a speed junky. Around here, you can find a sled that needs carb cleaning or a track for a couple hundred and harvest the motor. I have 3 motors just sitting in my parts room that cost me nothing.
Anyways, fan cooled would be great for trails, no issues there. You will probably have to step down a size or two on the mains and pilot jets, and adjust the needle a clip or two but it wouldn't be too bad. I personally put a 440 fan 2 stroke sled engine in a golf cart, and did not re-jet at all, had no issues.
Power wise, you will have no issues whatsoever, but they are loud. Also, as toystory said, make sure the rest of the kart can take it.
DixieRect
I'm a speed junky myself and would love as big of a fan cooled motor I can get. would there be much modding using the sled motor cvt, is it similar to the go kart/subaru set-up?
Kaptain Krunch
Pro Junk Collector
vermont
Wouldnt have to change much in the clutching. Exact same thing as we use in our karts, obviously far more rugged, and adjustable/rebuildable to boot. just make sure you get the center to center distance right on your clutches. alignment is also crucial. Only issue with sled motors is you will almost definitely have to do a double jackshaft setup to get the proper reduction. a 440 fan will push you as fast as you want to go, most 440 fans will do at least 55-60 on the snow.
