The first thought that comes to my head is that an Animal is likely engineered to rev higher. While, with the right gearing that may be of benefit to you, I have no idea what the low-down torque numbers might be like. For the trails, I think I'd be inclined to go with the big-block. The fact that it's a "work" engine, does not detract from the potential performance or reliability. Easily 90% of the engines we use on this forum are of the same type.
For trail riding, you'll want to consider a CVT, such as the Comet 40. It really will maximize what you can get out of your engine. Also, powertrain goodies like CVT's and clutches do tend to be more expensive in the 1" shaft size than the 3/4" shaft size.
