Which CVT would be best?
NapO
Canada
I currently have a two speed jack shaft set up on my go kart. I'm running a modified gx160 probaly pushing up to 9 or 10 hp with 16 tall inch tires. I smoked my clutch today trying to get out of a small ditch. I'm wondering if i shoud get a tav30 for my kart or cvt in general? im running a 61 tooth gear on the axle.
Blazkowiez
Kart Aficionado
Houston, Texas
Series 30 would work just fine. With a 61tooth gear on the axle given its 1/2 in pitch i'd run a 10 or 11 tooth sprocket on the jackshaft.
NapO
Canada
i was think of getting one of those ones where driven and driver pulleys copies but everything else on the torque converter is genuine comet should be ok right? i'm think im gunna need the comet to have ratio of more then 2:1 in order to get those big tires movin
Blazkowiez
Kart Aficionado
Houston, Texas
Yeah, BMI seems to be selling those very reasonable. The clutches don't seem bad. Yeah, you'll be fine once you get the torque converter.
