where to find sprocket?
acg23
bay area
i needa 60 tooth steel sprocket 1.5 id bore with no mounting holes for #35 chain. i would appreciate any replies to where i can get one of these. thanks. :cheers2:
Blazkowiez
Kart Aficionado
Houston, Texas
I'm not sure where you can find something with no mounting holes period but if you don't mind some holes any Oregon dealer should be able to order you one with as little as 4 holes.
solomon
ca
I got a 60T 4 bolt sprocket on ebay for $19 shipped, but Polaris a local retialer could get me one for as low as $14.75. So check retail stores before ordering online. Good Luck!
acg23
bay area
thanks for the tip. will #35 chain hold up on a 5hp minibike? it has some weight to it.
acg23
bay area
yea/ thats what i figured. you think a 60 tooth sprocket and 12 tooth clutch would work?
solomon
ca
Yea 5:1 Gear ratio, it should be fine on a mini bike, What size tire you using?
acg23
bay area
i was hoping to get a 15 inch donut but the 16.5 are more common. would the 16.5 be too big for the clutch?
solomon
ca
If you want a 5:1 Gear Ratio I think you should get a smaller tire like 14" or 15" or smaller in height.
