Whats model of my engine please
Dean B
German queens England
Hi there guys, I'm new to forum going to introduce my self in separate thread in a minute.
I have an old 2 seater kart, I would like to know what's name and brand of my kart and what's model number of the Briggs and Stratton engine in my kart.
Thanks in advance guys as I no this site will help me as I can see loads of help being given out as I read threw some people threads on here.
Thanks for reading guys
afremont
houston
It should be stamped into the metal shroud that the pull rope is inside. You should be able to find some numbers on it. Otherwise, it's pretty much like the one on my Carter Super Wheels cart. It's 5HP and uses a pulsa-jet carb, that should be about all you need to know to get parts for it. Depending upon the age, there are some differences in the carb setup. Most likely it doesn't have a removable main jet. They want a small fortune for a new fuel tank or carb, about $85 each for new OEM parts.
Dean B
I've took my tank off to clean it out and and put tank back on now the kart just starts up and sits there started up then when you give it throttle by pushing down throttle pedal the engine don't Rev up at all, kart was all fine before I took tank off but when taking the tank off on this engine I think I've messed up governor and throttle linkage??
Is there anyone with knowleged on these engines, and I will defiantly look for numbers stamped on Stroud tomorrow thanks for that bit of information my friend.
Poboy kartman
Senior Moments Member
White Settlement Texas
Well Dean....I almost don't want to help people who don't fill out a profile location.....but....you've been told where to find the model #'s....and you can either Google up a manual online....post the #'s here....or.....for crying out loud...... at least post some pics!!!!!! Jeeze:mad2::surrender:
afremont
houston
If it works anything like mine, and it certainly looks like mine, then the cable pulls on a slide that rotates a mechanism on the backside. Mine was missing whatever tugged on the engine throttle/governor linkage. I rigged up a little spring so that when the mechanism rotated, it pulled down on the throttle linkage. When I let off the gas, the mechanism rotates back and, when it reaches its stop, it pushes the throttle rod to the idle position.
You'll have to get down on your hands and knees to see if that's how yours is set up. If it is, there should be some kind of spring that connects from the back of the tank mechanism to the linkage attached to the engine. Since mine was missing, I'm not sure I have it right now, but it does work. It was an absolute pain to hook it up. It must come apart very easy when you remove the tank. Without it, nothing happens when you press the throttle other than the mechanism on the tank rotating.
---------- Post added at 06:16 PM ---------- Previous post was at 06:05 PM ----------
http://youtu.be/B12rX9pWtTk Going to try this tomorrow as I think this is what needs doing to my kart to set up the throttle again, any suggestions?
You shouldn't have to mess with the actual governor lever. The very next video shows how the mechanism on the tank connects to the governor arm/throttle linkage via a spring. That is what I was trying to describe. The spring I made is connected something like that, but not exactly. It accomplishes the same thing though. It pulls that long rod and the governor lever down when the mechanism on the bottom of the fuel tank rotates.
Dean B
Poboy I will get more pics tomorrow and sort my profile out properly.
And Afremont your correct about that spring I've connected that and was a little bit of pain to connect, the karts throttle was ok before I took tank off to clean it out, never worked on one of these engines before and they aren't half weird engines to me.
I will get more pics, tomorrow and upload them thanks for replying guys :thumbsup:
