If it works anything like mine, and it certainly looks like mine, then the cable pulls on a slide that rotates a mechanism on the backside. Mine was missing whatever tugged on the engine throttle/governor linkage. I rigged up a little spring so that when the mechanism rotated, it pulled down on the throttle linkage. When I let off the gas, the mechanism rotates back and, when it reaches its stop, it pushes the throttle rod to the idle position.
You'll have to get down on your hands and knees to see if that's how yours is set up. If it is, there should be some kind of spring that connects from the back of the tank mechanism to the linkage attached to the engine. Since mine was missing, I'm not sure I have it right now, but it does work. It was an absolute pain to hook it up. It must come apart very easy when you remove the tank. Without it, nothing happens when you press the throttle other than the mechanism on the tank rotating.
---------- Post added at 06:16 PM ---------- Previous post was at 06:05 PM ----------
http://youtu.be/B12rX9pWtTk Going to try this tomorrow as I think this is what needs doing to my kart to set up the throttle again, any suggestions?
You shouldn't have to mess with the actual governor lever. The very next video shows how the mechanism on the tank connects to the governor arm/throttle linkage via a spring. That is what I was trying to describe. The spring I made is connected something like that, but not exactly. It accomplishes the same thing though. It pulls that long rod and the governor lever down when the mechanism on the bottom of the fuel tank rotates.
