What would be more worth it..?
Magice
I currently need an easy to attach motor for my kart and am looking for the fastest solution:
What should I do?
1. Get a new aluminum bearing block for 5hp briggs (raptor3 block or something) This would cost me about $60 in all tops. I have all parts to build onto block.
2. Buy my friends 5.5hp low use ohv Honda for 100 dollars. He ran it on a gokart but never pulled the governor.
I was also thinking of possibly attaching my gx340.. but that thing weighs like 100lbs.
Out of choice 1 and 2, what would better. Are hondas light compared to an aluminum bore briggs?
sayre315
Rupp enduro
Oklahoma
i would say if you got about $120 build up a raptor briggs
weld up your own exost (if you have axcess to a welder) and buy a racin cam, rod, flywheel, head, valve's/valve springs and cool stickers :)
ed1380
Banned
ATL, GA
or take that same money and find a used 2 stroke
$200 gets you a brand new 125cc w/ 4sp and maybe reverse (not on ebay ATM)
$300 might get you a 500cc w/ 5sp
Magice
That would be a pain in the *** to attach though... hmm
I've been thinking of rebuilding my gx340 and maybe attaching that.. although that may be too heavy on my flexy frame
Kenny_McCormic
Kartless....
Michigan Troll
Our system is more accurate. My opinion.
I think there is a conspiracy against our friends to the north...
I saw a sign today that said "Drink Canada Dry"
I do prefer thousands of an inch for fine work but its a PITA to do fractal work with "american" units whereas the metric stuff is all in tens.
Magice
A good chunk of measurement in industrial design kind of stuff is done in imperial here in Canada still..
iwanttogofast
no fact...our smallest is a inch(smallest standard size) we can go to thousandths of inches....metric can got to thousandths of cm and mm...being way more accurate...because its a smaller measurement
modelengineer
Lord of the noise
Sydney, Australia
You can't say one is more accurate than the other. People measure things in ten-thousandths of an inch, neither system is more accurate.
(Metric FTW tho :roflol: )
Russ2251
AZUSA:Powered by LAWN-BOY
Time to break out my metric adjustable wrench.
